How to restart Dynatrace components on Kubernetes
annam
Visitor
Hello
I'd like to know if there's documentation on how to properly restart Dynatrace components (Webhook, Operator, OneAgent, ActiveGate, etc.) in a Kubernetes deployment.
I'm new to the platform and haven't found any support links.
Thank you.
3 REPLIES 3
g_kat
Advisor
Hi @annam ,
They can be restarted as usual kubernetes components using kubectl rollour restart on the dynatrace namespace.
Keep in mind different components have different types:
  1. Operator - Deployment
  2. Webhooks - Deployment
  3. CSI Driver - DaemonSet
  4. OneaAgent - DaemonSet
  5. ActiveGate - StatefulSet
Also, here is some relevant documentation about components maintenance:
https://docs.dynatrace.com/docs/shortlink/guides-k8s-update-uninstall-operator
George
"Jack of all trades and master of none, still better than master of one."
Hi George,
Thanks for your response. I tested the commands in my environment and they worked. Your comment about the different component types helped me better understand the process.
Best regards,
Ana
Islam_Zedan
Champion
You can use a simple command like the below to restart the AG
kubectl -n dynatrace rollout restart statefulset/<ACTIVEGATE-STATEFULSET-NAME>
Please check that from documentation
https://docs.dynatrace.com/docs/shortlink/guides-k8s-update-uninstall-operator#update-ag-pods
Islam
Dynatrace Certified Professional - Dynatrace Partner - Yourcompass.ca
