24 Jan 2023
11:26 AM
08 Feb 2023
10:34 AM
Ana_Kuzmenchuk
We are monitoring the application that is hosted on Kubernetes. Suddenly the process on a particular host goes into a stopped state every 4min. However, this issue was only in Dynatrace, on the client end they did not find any issue with the process. This is triggering multiple problems and the client is very concerned about it.
08 Feb 2023 10:35 AM
Hi, @Harmera12, did you maybe find an explanation for such a behavior? We'd really appreciate it if you share the solution with the Community in case anyone else is facing it too 😊 thank you!
