18 Sep 2023
04:07 PM
19 Sep 2023
07:50 AM
When there are problems logged for a K8s cluster, the filters on the problem page for K8s clusters doesn't find the problems generated from that cluster. Please fix the filter or the metadata to allow the filters to work as expected.
21 Sep 2023 01:21 PM
I don think this falls under a RFE. moving it to Q&A
@Bill_Demsky can you provide an example of the filter that you are using? I've tested it out on my end and it is functioning as designed. What cluster Version are you on?
05 Oct 2023 03:44 PM
Hi, I do face the similar issue. Can any one has hints to filter out cluster level problems / filter to search problems under cluster . I can get problems if I use at workload levels But I want to see the filter with Cluster level. How many problems under each cluster in problems page.
05 Oct 2023 03:58 PM
I'd Suspect that the Cluster Level monitoring isn't completed. Hence why you dont see them in the problems page. You can verify by going to a node and looking to see if the K8 Cluster is listed in the properties.
05 Oct 2023 04:22 PM
Yes. I cloud see the cluster details in a node properties. and I tried with tagging the cluster name as well. But Still i can't see the problems if I filter as Entity : Kubernetes Cluster(KUBERNETER_CLUSTER). It result with 0 problems.
05 Oct 2023 06:34 PM
Make sure that your time frame is wide enough to include a kubernetes problem. What cluster version are you on? In our instance it is working as designed on the most recent cluster version:
If you are at the most recent version of the Cluster then you might want to open up a support case.
As a work around for the time being I recommend crating a Auto Tag that provides the value of the K8 Cluster to the related hosts, processes and services. This will then allow you to sort problems by tag being "K8 Cluster:<Value>"
05 Jun 2025 02:32 PM
Hey @Bill_Demsky , did you manage to find the solution to your problem? If so, it would be amazing if you've shared it with the rest of the Community! If not, let me know, and I'll look for some further assistance 😊
05 Jun 2025 03:56 PM
Hello.
You can use the following alerting profile as filter:
BR
