Kubernetes - enabling node level monitoring
We have disabled Log monitoring at the global level, hence whenever new nodes are created at the KVM level we are enabling it manually. Is there any way we can enable Log Monitoring for Kubernetes node level Log Monitoring?
Venkat
techean
Inactive
Dont seem to find any documentation reference to kn8s nodes. Its better you also raise a support ticket or RFE as of now along with this post.
KG
