02 Oct 2023 05:09 PM
Hi.
We have an OpenShift cluster successfully monitored with Dynatrace Operator. We are trying to monitor the OpenShift HAProxy deployed using Ingress Operator (https://docs.openshift.com/container-platform/4.12/networking/ingress-operator.html). This process does not support full-stack monitoring so the only option is to get metrics exposed with Prometheus. We have tried the following approaches:
Any suggestion?
23 Nov 2023 01:57 PM
Additional info about this issue:
This extension as well as any other extension 2.0 cannot be deployed in OpenShift or Kubernetes, because it is not supported yet. In other words you cannot deploy any extension to containerized OneAgent or ActiveGate. For now it is only possible to deploy HAProxy (Prometheus) extension to non-containerized OneAgent or ActiveGate (outside of Kubernetes/OpenShift). |
HTH
17 Jun 2024 12:52 PM
does the extension still not work when deployed in OpenShift?
05 Jun 2025 02:33 PM
Hey @joseandrescalvo , did you manage to find the solution to your problem? If so, it would be amazing if you've shared it with the rest of the Community! If not, let me know, and I'll look for some further assistance 😊
