19 Jul 2023
10:09 AM
20 Jul 2023
07:41 AM
Dear All,
A use case for the Pod/Process is unavailable.
Whenever a respective team manually Deleted (Terminated) the Pod, the Pod spins up with the new dynamic name and UID. So, generally, it should be the right behavior.
The challenge here is that Dynatrace expects the previously connected Pod name/UID and that will not be the same after deletion/termination, therefore, generating a problem.
How to overcome this situation?
Babar
18 Dec 2023 10:12 AM
Hello @Babar_Qayyum ,
Do you still face this challenge, or have you found the solution already? Let me know, so we could proceed further 🙂
