18 Oct 2024 07:28 AM - last edited on 18 Oct 2024 08:34 AM by MaciejNeumann
Hello!
Can anyone tell me how to set up thetaray-openshift monitoring in dynatrace?
Currently, I have oneagent installed and monitor the system status, but not the application
18 Oct 2024 11:02 AM
Hi @Esipovich
It depends on how you have instrumented the OpenShift, I believe you have used : https://docs.dynatrace.com/docs/shortlink/how-it-works-k8s#host
You should follow the attached method for app observability : https://docs.dynatrace.com/docs/setup-and-configuration/setup-on-k8s/installation/app-observability-...
Here is the most recommended K8s / OpenShift monitoring : https://docs.dynatrace.com/docs/setup-and-configuration/setup-on-k8s/installation/cloud-native-fulls...
And it also depends on the App owner monitoring requirements it's the key point behind the monitoring decision.
KR,
Peter
