DQL
Metric Key not available ?
Etienne1
Advisor
Can i use this metric key : "builtin:tech.generic.cpu.totalTime" in Grail cause i need it in my DQL, it does not appear in the documentation (https://docs.dynatrace.com/docs/observe-and-explore/metrics/built-in-metrics-on-grail)
And I don't see it supported by Grail in the “metrics” page.
Does it exist but is not referenced, or does it simply not exist?
3 REPLIES 3
AntonPineiro
You can find it here.
And some timeseries CPU examples.
Best regards
Thank you for your reply.
My question was more whether I could use this particular metrics “builtin:tech.generic.cpu.totalTime” and not another one.
As you can see, it doesn't appear in the documentation, so I was wondering whether it existed or not.
Check example 3, they are using classic selector in DQL. I think you can follow similar approach.
Best regards
