Need a way to use DQL for searching extension logs
deni
Advisor
I need help with searching logs from the SSL Certificate Monitor extension. I noticed that if the monitored site is down or if there is an error reading the certificate, the certificate just disappears from the discovered certificates. I found some logs in:
./remotepluginmodule/log/extensions/datasources/com.dynatrace.custom.python-certificate-monitor/python3.log
Is there a way to read these logs through DQL and set up an alert if such issues occur?
Thanks!
Regards, Deni
Dynatrace Integration Engineer at CodeAttest
3 REPLIES 3
RohitBisht
Dynatrace Pro
Dynatrace Pro
You can install OneAgent on the activegate host and then enable log monitoring for the file.
RB
How can I enable this log monitoring?
I tried to add a custom log configuration in settings: Linux path: /var/lib/dynatrace/remotepluginmodule/log/extensions/datasources/com.dynatrace.custom.python-certificate-monitor/python3.log
but
fetch logs
| filter matchesValue(content, "8443")
| sort timestamp desc
still don't return anything. The digit is a port number which exists in the file:
sudo grep 8443 . -R | grep 2025-05-12
./remotepluginmodule/log/extensions/datasources/com.dynatrace.custom.python-certificate-monitor/python3.log:[3dacb2c3-3e7b-3354-91b4-6cf6d488d5d6][-4727436546405702787][37757][out]2025-05-12 13:21:40,036 [DEBUG] (ThreadPoolExecutor-0_0): Check bindings: [ProcessPortBinding(address='78.83.113.249', port=8443, pid=None)]
..... and a lot more
/var/lib/dynatrace$ pwd
/var/lib/dynatrace
Its a 2 step process as stated here: https://docs.dynatrace.com/docs/shortlink/log-monitoring-custom-source
The entire process consists of two parts:
  1. Source definition (custom log source configuration), which is described on this page.
  2. Log acquisition (adding logs to storage), which is described on Log ingest rules.
    I believe step 2 is missing for you, once you do this content of log file should be there, try to search for check if the logs are flowing in first and then you can perform specific searches like port number. Hope this helps.
RB
