14 Jul 2025 04:58 PM
14 Jul 2025 05:57 PM
Hi @szimsley ,
You can still display the bucket details using the following command:
| fieldsAdd dt.system.bucket
Then apply the filter like this:
| filter dt.system.bucket == "default_logs"
Does that work for you?
14 Jul 2025 07:24 PM
Hey @Akhil-Jayendran, we are aware we can add the field to each query, but we wanted to be able to have that field displayed by default. We work with several buckets and currently users don't have easy access to see which of bucket their data is in, making it so their queries are less efficient. This is especially important when using the logs app as you have to go into the advanced mode just to add the ability to view that field.
As we transition to using segments, having that information available to our users would be beneficial for them to know what bucket they needs to select.
17 Jul 2025 08:21 PM
@AlexanderSommer, here is the post from the Automation Guild meeting
