filter for Kubernetes label key
roberto_camp1
Frequent Guest
I have the following DQL started to detect k8s Deployments with a certain label :
fetch dt.entity.cloud_application, from: -30m | fields id, workload.id = id, workload.name = entity.name, workload.type = arrayFirst(cloudApplicationDeploymentTypes), workload.labels = cloudApplicationLabels, workload.annotations = kubernetesAnnotations, workload.resourceUid = resourceUid, workload.conditions = kubernetesConditions, workload.age = record(start = resourceCreationTimestamp, end = now()), cluster.id = clustered_by[dt.entity.kubernetes_cluster], namespace.id = belongs_to[dt.entity.cloud_application_namespace], namespace.name = namespaceName
// Filters: [cluster,namespace,workloadLabels,workloadType]
| filter in(id, classicEntitySelector("type(CLOUD_APPLICATION),toRelationship.isClusterOfCa(type(KUBERNETES_CLUSTER),entityName.equals(operations))"))
| filter in(id, classicEntitySelector("type(CLOUD_APPLICATION),toRelationship.isNamespaceOfCa(type(CLOUD_APPLICATION_NAMESPACE),entityName.equals(services))"))
| filter workload.labels[`com.acme.project`] == "98417"
| filter in(workload.type, "KUBERNETES_DEPLOYMENT", "OPEN_SHIFT_DEPLOYMENT_CONFIG")
My question is, instead of doing a filter on the specific label value "98417" for the label key `com.acme.project`, can I simply return all the kubernetes Deployments that have the `com.acme.project` label, regardless of the value of the label?
Hi @roberto_camp1 ,
It’s possible. You can use Dynatrace Pattern Language(DPL) to match if any value is in com.acme.project variable and if this variable even exist. Then, you can filter the new variable so that it does not have a null value, in case the com.acme.project variable does not exist, the new variable will have a null value. In your example you can do something like this:
| parse workload.labels[`com.acme.project `], """DATA:com.acme.project"""
| filter isNotNull(com.acme.project)
Hope it will help,
Bests
Michal
