21 Jul 2022
05:45 AM
03 Aug 2022
05:18 AM
AgataWlodarczyk
I need to create a dashboard with both trending and cumulative results. The metric type is gauge. Ideally, the cumulative result is flexible for the timeframe (i.e. start of the day, last week....).
Is there a way to create a tile with cumulative results? The closest idea I had was "rollups" but that is limited to 60 mins and not sure it is even the right result.
Hi, @ronmacdonald , are you using some specific metric for this dashboard? Is it a builtin metric or a custom one? Can you provide more details about it?
thanks
09 Aug 2022
11:31 AM
16 Dec 2022
02:35 AM
AgataWlodarczyk
So what I'm trying to do....
I have a metric (custom) that captures the number of logins.
I want to depict:
This is a gauge metric and just looking for an aggregation solution to be cumulative number for a time period.
