17 Aug 2021 11:17 AM - last edited on 31 May 2023 01:05 PM by Michal_Gebacki
We are trying to get data of request attribute which is created for Loadrunner request tagging. So we need load runner tagged request attribute data as a metric to retrieve Avg and 90% response times.
We have created a metric with Avg as aggregation but not 90 percentile. is there a way to get that 90 percentile data other than Multi dimensional analysis? Also, is there any better way to copy chart table data to excel?
17 Aug 2021 12:12 PM
You don't need to create custom metric. You can use Data explorer to create output for Response time 90th percentil filtered by your request attribute (and/or split by service) and use Table format to visualize preview. If you need then switch to Data tab, you can see metric definition that you can use to export data points via environment api v2 (in json format).
13 Oct 2021 08:49 PM
Data explorer doesn't work and filter individual requests for any particular service. So I had to create custom metrics for particular service so I can filter and split by individual requests for that services. But the thing is, with custom metrics request attributes don't work. Data explorer shows option to filter by request attribute but when I try to filter it, it doesn't work. Also custom percentile doesn't work for Custom metrics. so is there any way to get graph filtered by request attribute and use it on dashboard?
13 Oct 2021 09:00 PM
Can't you just mark them as "key requests"? In that case it should be possible to filter on specific requests.
13 Oct 2021 09:07 PM
yes with key request we can filter on specific ones but we can't filter key request with request attributes..
