14 Nov 2022
03:15 PM
23 May 2023
01:34 PM
Michal_Gebacki
I have tried to use dynamic filters on a dashboard for the test but that doesn't work with the tag:
---Rules:
---First try, no choice selectable and no filter applied:
---Another shot completely random ok:
---I had another even if it's not accepted:
---Suppress the first, and hope the filter works without the choice selected in blue ???
What am I missing here?
Another thing that could be really cool, is to add a label/id/descriptor to the filter and chose on which tile (in the tile configuration) to apply it. For that, you could have a dashboard with, Host, Process, and Services dynamic filtered on every application without a switch of dashboards. If I'm not clear I will send a building picture with paint :).
Thx for your reply
14 Nov 2022 03:17 PM
***Like that you could have a dashboard with multiples Dynamic filters,
21 Nov 2022 01:51 PM
Hello, MY BAD, it was a misunderstanding of the field "Tag key" in the rules you have to insert something that define your TAG like a Metadata for exemple. And then appears a list of choice when you use it.
Then why just not put the filter "TAG" in fact the most usefull^^
Because not everyone use MONACO to build rules for everything 🙂
Anyway case closed (except why that partialy filter something with the contraption method used above, it doesn't matter anyway.) Enjoy your Dynatrace trip Bye
