Dashboarding
Data Explorer - Metrics - default()
EvaWang
Participant
Good mroning,
I see the DT documentation and make a understanding of 'Default transformation' (https://docs.dynatrace.com/docs/dynatrace-api/environment-api/metric-v2/metric-selector), but I still have a question about the default(0) like below:
Same Metric except default(0):
1.  without default (0) - builtin:billing.ddu.metrics.total:splitBy():sum:auto:sort(value(avg,descending))
2. with default (0) - builtin:billing.ddu.metrics.total:splitBy():sum:auto:sort(value(avg,descending)):default(0,always)
3. Compare with UI
I just want to aviod the no data situation and used default() in query, Why is there a diff in the result?Should I use it?
Eric_Yu
Dynatrace Mentor
Dynatrace Mentor
Can you change the fold transformation also to sum and show the result?
Eric Yu | LATAM ACE Consultant
It works, thank you so much!
