16 Apr 2025
07:16 AM
17 Apr 2025
09:07 AM
How to get tech.jvm.threads.totalCpuTime metric for 2 management zones in data explorer?
eg query
builtin:tech.jvm.threads.totalCpuTime
:filter(and(or(in("dt.entity.process_group_instance",entitySelector("type(process_group_instance),mzname(~"mz1~",~"mz2~")")))))
:splitBy():sort(value(auto,descending)):limit(20)
error:Metric data is missing from the result! For the dimension 'Thread group' the query was limited to the top 100 dimension values with the most data points.
17 Apr 2025 12:04 AM
You will have to alter the expression to properly make use of the or() logic. The format (with line breaks added to enhance readability) is as follows
or(
in("<entity_type>",<entitySelector expression for MZ1>),
in("<entity_type>",<entitySelector expression for MZ2>)
)I believe this is similar to your question about synthetic tests from two management zones, where a similar approach was suggested.
