26 Jun 2024
05:23 PM
01 Jul 2024
08:52 AM
In Dynatrace dashboard not showing all data ex:- No data and change time frame or management zone
26 Jun 2024 07:02 PM
Most likely you don't have metric data coming in to Dynatrace for those metrics or you don't have permissions.
27 Jun 2024 08:40 AM
we have given permissions as per the Dynatrace recommendation document only. However, the dashboard showing Host availability, Network Metrics, CPU & Memory utilization but few things not showing up like Instance data, last backup data, Db performance metrics. Please suggest on this.
27 Jun 2024 10:14 AM
You need to make sure that you have the rights permissions to read these metrics from Oracle DB, please check the below document for further details.
https://docs.dynatrace.com/docs/shortlink/extend-oracle#before-you-begin
Islam
27 Jun 2024 12:51 PM
I have re-validated just to confirm and we followed same commands after creating user also executed those listed commands again in the below mentioned blog but still not showing the data.
01 Jul 2024 01:29 PM
Can I have any further advise to resolve the Dashboard showing "No data" issue please.
18 Nov 2024 01:40 PM
Hello, were you able to solve it? If so, could you please tell us how you did it? Thank you.
13 Aug 2024 02:42 PM
Hi @cramesh
Have you managed to solve the problem? It would be great if you shared the solution with the Community users 🙂
