Is there a way to delete custom multi-dimension analysis chart
chuan_sern_wong
Advisor
Is there a way to delete away custom multi-dimension analysis chart created by non administratror user ?
We try to use the default super admin, but still not possible remove these custom multi-dimension analysis chart
skrystosik
For now as I know you can do it via GUI only from account that has created it. I know that there were some improvments in dynatrace configuration API to allow such things. I don't know if it cover multidimensional analysis as well. You can read more here:
https://www.dynatrace.com/news/blog/new-configuration-api-enables-efficient-configuration-as-code-ma...
Regards, Sebastian
