Measure user actions problem: seconds instead of milliseconds
Adrian_Kefirov
Observer
Hello friends,
I create a dashboard to measure the time of all user actions through a user session query:
"SELECT name ,AVG(duration)  FROM useraction WHERE (name IS NOT NULL) AND usersession.stringProperties.clienttype="Corporate" GROUP BY name ORDER BY avg(duration) DESC"
Here is one big BUT:  all times are in milliseconds and I want to make it in seconds because will be easier for a business .
user actioin 1 - 36,305 ms
user actioin 1 - 10,870 ms
user actioin 1 - 9,865 ms
user actioin 1 - 5,784 ms
user actioin 1 - 5,151 ms
and etc.
I try different ways to convert these milliseconds to seconds but without luck.
Can you give me an idea how to do it?
rastislav_danis
DynaMight Pro
DynaMight Pro
Division operation (duration/1000 f.e.) is supported, but not with aggregation at this time (error message from UQL: "Mathematical Operation with aggregator functions is not yet supported!"). You can export USQL result (via API https://www.dynatrace.com/support/help/shortlink/api-usql) and convert it externally.
