Monitoring datastore
mauricio_capiz
Participant
Is there a way that I can create a chart and add it to a dashboard with the available and used space for cluster datastore?
Mauricio.
6 REPLIES 6
Babar_Qayyum
Hello @mauricio_capiz
If I am not mistaken, the virtual layer support is available only for VMware, so in the case of VMware, we can monitor the datastore-related activity on your VMware platform.
Babar
Hello Babar,
Thanks for you answer.
The client wants to monitor the datastore through a dashboard and I can't find how to do. It's possible?
Regards.
Do you have VMware?
Babar
Yes, the client have VMware.
Regards.
In such a scenario, they should be able to plot the chart and display it on the dashboard. I do not have VMware, otherwise, I could share the step-by-step process.
Babar
ct_27
DynaMight Advisor
DynaMight Advisor
We have been asking the same for a while as well to help monitor our VMware datastores.  I'm sending this chat to our VMware Engineer to contribute with details.   We ended up purchasing the VMware Alert extension so that VMware alerts related to Datastore would be caught by DT and raise a problem.  It would be better though if DT could just monitor the Datastores directly.
Jason Shuff - Yale University
I might be tough on Dynatrace but I believe in the product.
