26 Feb 2024
03:39 AM
27 Feb 2024
09:28 AM
Hello All,
I am trying to add dynamic filters on my dashboard. Specifically, I want to filter by Azure tags. Is there a way where I can achieve this? Adding tags manually would be a cumbersome task.
Example of Azure tags
26 Feb 2024 05:35 PM
Hey @PacoPorro,
Thank you! That worked. However, it does not filter my dashboard for some reason. When I try to with [Azure]env tag and select 'dev' it does not filter and displays for all environments. Any idea why that would be?
27 Feb 2024 08:56 AM
It can be related to the metrics shown in your dashboard.
The metric should contain the dimension related to the filter (Example dimension host if the filter has a host tag)
