Oracle DB insight dashboard
oakdag
Observer
Do you have an Oracle DB insight dashboard that you are currently using? Can you share? Or where can I find it?
Regards.
16 REPLIES 16
AntonioSousa
I'm not sure what the current rules for sharing this type of information might be. I might be able to help. Probably @MaciejNeumann , could we have a hint on the best way to eventually share this type of information?
Antonio Sousa
As long as there is no confidential information in it (like passwords, environment IDsAPI keys, IP addresses, or name of your clients), sharing it in the Community is totally ok 🙂
If you have any questions about the Forum, you can contact me at maciej.neumann@dynatrace.com
ryan_ott
Dynatrace Mentor
Dynatrace Mentor
Attached is the Dashboard JSON for one that I use with my current customers. It should give an idea of how we can chart out the various additional metrics that are available with Oracle Insights.
Let me know if you have any additional questions.
-Ryan
ACE Consultant, Dynatrace Services
Hi
Thanks @ryan_ott but I don't see how to download the attachment  🤔
Is it only me that is so blockhead?!
Yos
dynatrace certificated professional - dynatrace primer partner - Matrix Soft Ware Division - Israel
You should be able to see 'Oracle Insights.zip' in my original reply, and click to download.
Hi @ryan_ott
We can see it
But there is no download option 🤔
Yos
It is strange - I don't see an option to download directly now either... As @AntonioSousa mentioned below, it seems you are able to directly visit the link in the source code to start the download.
Here is the link: https://community.dynatrace.com/pssft35649/attachments/pssft35649/Dashboarding/1875/1/Oracle%20Insig...
Let me know if that works.
-Ryan
ct_27
DynaMight Advisor
DynaMight Advisor
Thank you. Great work.
AntonioSousa
I was also unable to download, but I saw the zip file. I checked the HTML source code and was able to download afterwards. Maybe someone else can confirm this?
Antonio Sousa
Same here. I got the link from the source code, so I could download the file.
Community Team
Community Team
I've found the issue with downloading the attachments and fixed it - now you should be able to download it correctly, directly from @ryan_ott post 🙂
Thanks @MaciejNeumann now downloading works as a charm !!!
zietho
Dynatrace Champion
Dynatrace Champion
cool stuff, thx for sharing!
Just imported it into our test system - one note - you might want to use heatmaps to do the first one instead. In DT 1.232 (heatmap will hit the stage with 1.230) would look like...
That is super cool!
UstatSingh
Newcomer
Thanks. This is really great!
