Same color in dashlet chart
dmascolo_extern
Newcomer
Hi all,
I'm trying to create a dashlet (using custom chart - key user action) with the following measure:
  • action count
  • action duration (average)
  • action duration (75th percentile)
  • action duration (95th percentile)
I'm facing the following issues:
  • I can't have 2 measures with the same aggregation (percentile)
  • I can't change color of measures added: this result in a understandable tile
As example see image attached.
Any suggestion to troubleshoot this?
regards,
Davide
3 REPLIES 3
skrystosik
I have the same issues as well. Unfortunately built in charts are not very useful for such charting (two metrics on the same chart with different chart types). There should be at least option for defining opacity for stackbar or something like that.
Regards, Sebastian
roman_windischh
Dynatrace Champion
Dynatrace Champion
Hi Davide! Both deficiencies will be addressed soon. Here's a preview how color selection will look like in future:
Image doesn't work 😞
Regards, Sebastian
