Small annoyance when using report url
henk_stobbe
DynaMight Champion
DynaMight Champion
When you click on a report url from a subscribtion it will transfer you to a dashboard with the  correct report time-slot:
But when you login (or when you are already logged in with any time-slot)
Dynatrace set the time to the default 2 hours. Why?
Thanks Henri,
KR Henk
rastislav_danis
DynaMight Pro
DynaMight Pro
Hi Henk, probably you have url with custom timeframe defined. Do you have any default timerame defined in dashboard definition ?
Hi Danis,
Thanks for your reply!
Url uses:
gtf=c_1640995200000_1643673600000 (= Januari)
Dashboard:
So I assume a little bug (-;
KR Henk
