Dashboarding
changing time frame -Data explorer
idand
Participant
Hi Team,
we are trying to create a dashboard that will show us results for the last week,
while the resolution is 1 day.
The Problem that resolution display results timeframe from 3:00-3:00 instead 00:00-23:59 .
can someone explain how to change it ?
Thanks in advance.
Idan
3 REPLIES 3
AntonPineiro
You can see internal granularity leves.
I cannot understand you which problem you have. Could you please elaborate a little more?
Best regards
@AntonPineiro the issue is that Dynatrace does not have support for timezones in Data Explorer.
See more also in this Product idea https://community.dynatrace.com/t5/Product-ideas/RFE-API-with-timezone-support/idi-p/152443
You will always end with incorrect buckets unless you are in the GMT timezone.  This is especially noticeable when your granularity is 1 day.
Thank you for explanation @Julius_Loman 😎
Best regards
