load browser action metric as per the geo location
amitbsht321
Contributor
Hi Team,
we are trying to fetch the data of Action duration- load action (by Brower) [web] using data explore. The requirement is to get the data as per the geo location.
We are not seeing any metric to set the bifurcation on basis of geo location apart from synthetic metrics.
Is their way to achieve the same.
Amit Singh Bisht
4 REPLIES 4
Yosi_Neuman
DynaMight Champion
DynaMight Champion
Hi @amitbsht321
IMO you can use User sessions query for this with select like: "select usersession.country,AVG(visuallyCompleteTime) FROM useraction where type="Load" GROUP BY usersession.country"
And then pin it to dashboard
HTH
Yos
dynatrace certificated professional - dynatrace primer partner - Matrix Soft Ware Division - Israel
Hello @Yosi_Neuman
Thanks a lot for you quick response. Yes we are getting data, as expected.
Just need one assistance from you. How to fetch the same data for a one specific application and a specific country i.e USA/UK ??
Amit Singh Bisht
Use Management zones for specific application.
KG
Hi @amitbsht321 ,
Add to the where of the select your application and the desired country, something like: select usersession.country,AVG(visuallyCompleteTime) FROM useraction where application = "www.easytravel.com" and usersession.country = "United States" and type="Load" GROUP BY usersession.country
More information about  custom queries can be found in documentation
HTH
Yos
