using numeric comparison in filter
sampathkumar
Frequent Guest
i need to create metric event where disk free  between  10%- 20%   . tried with  some metrics . but not working
following return no data
builtin:host.disk.available:filter(host.disk.available> 10):splitBy("dt.entity.host",dt.entity.disk):sort(value(auto,descending))
and more over how ti reference disk name .if i want exclude certain disk from monitoring
3 REPLIES 3
mark_bley
Dynatrace Champion
Dynatrace Champion
Not possible to have such logic in the metric query.
What you can do is create a warning metric event if the threshold passes de 20% threshold, and once it is less than 10% you send out a critical one.
This requires 2 separate metric events, but these will just be 2 metric-selector-based configurations.
https://docs.dynatrace.com/docs/shortlink/metric-events-metric-selector-events
These events may be filtered by an alerting profile that triggers just an email or slack to inform about a warning, or in the critical case could open up a ticket, this is just an example.
1. //metric event if the threshold passes de 20%//  how can i set it .
    for example i keep  1.  warning  < 20 %  and 2. critical for <10%  . can i set order or metricevent execution.
will this work 1. builtin:host.disk.free:filter(and(in("dt.entity.host", entitySelector("type(~"HOST~"),entityName(~"xxxx~")")),series(value,ge(77)),series(value,lt(90))))
2.  builtin:host.disk.free:filter(and(in("dt.entity.host", entitySelector("type(~"HOST~"),entityName(~"xxxx~")")),series(value,gt(77))))
And one more question. how can i add tags or custom metric data into alert description .
 i need customer metric for specific servers, specific mount point on some server.
will all metric event evaluated always for all metrics
  1.  both will get triggered if less than 10% is reached
  2. you can only alert on static threshold either above or below
You can add event properties which you can use to filter these events in an alerting profile or further down the line if forwarded to any ITSM.
