Dynatrace Managed Q&A
ActiveGate not connecting to cluster
vajrababu1976
Newcomer
ActiveGate not connecting to cluster, checked the TCP port connectivity. required services are running.
3 REPLIES 3
AntonPineiro
I would raise a support ticket.
Best regards
radek_jasinski
What information do you have in the ActiveGate logs?
Have a nice day!
lubrman
Advisor
Hi @vajrababu1976
You did not install the AG from the configured environment. Installation must be performed from the CMC due to the connection requirements.
Alternatively, follow the documentation.
https://docs.dynatrace.com/managed/ingest-from/dynatrace-activegate/activegate-diagnostics
