24 Sep 2024
		02:02 AM
		24 Sep 2024
		07:48 AM
Hello Gurus,
Does anyone have a successful use case or customer story on monitoring SAP MES(Manufacturing Execution System) using Dynatrace? Thanks.
Sincerely,
Leon
24 Sep 2024 08:12 AM
Hello @LeonHu
I've exposed other SAP use cases, Hana and abap.
As simple as possible, validate against the attached links and proceed with the most applicable scenario for your use case.
Just take 5 -10 minutes exploring the available options against your solution and select the best fitting.
24 Sep 2024 08:15 AM
hi @LeonHu
