24 May 2024 05:34 AM
Hello everyone,
I would like to ask about the system requirements for Dynatrace Managed.
Refer to the following documentation: https://docs.dynatrace.com/managed/managed-cluster/installation/dynatrace-managed-hardware-and-syste...
It states that for a Micro (max 50 HU) setup, the required resources are:
Currently, I want to do a POC for a prospect, who based on our calculations, will only consume 10 HU.
Since the POC will be conducted in their Dev/QA environment first.
Is it possible to reduce the resource requirements I mentioned above?
If so, what would be the minimum requirements?
Thank you.
14 Oct 2024 08:22 AM
It is little bit late answer, but If you want to showcase the Log Management in your PoC, you would need a 64GB RAM as the requirement for Log Management Classic is 64GB RAM.
14 Oct 2024 06:26 PM
Hello @agylpradipta
Regarding the POC raised concerns:
So:
Tip:
Managed requirements:
Wishing you successful POC.
KR,
Peter.
