Broker monitoring using Dynatrace Managed and appmon/dcrum
rpichardo
Inactive
what are the best options for monitoring a broker environment, we have Dynatrace managed, Appmon and also DCRUM.
3 REPLIES 3
harshal_pujari
Dynatrace Pro
Dynatrace Pro
Hi Robert,
For DC RUM, you can define the Broker as a software service with the HTTP analyzer and analyze the corresponding web services. That gives you a great fault domain isolation.
Depending on the Broker version,you can use the following plugin in App Mon to check Broker metrics. I would highly recommend to instrument this plugin in QA/Dev Broker (
https://community.dynatrace.com/community/display/...
Or you can install an App Mon agent. Please note that App Mon agent is per execution group within the broker.
I believe Dynatrace support for broker will be here in the next 3/4 months.
Hope this helps.
Harshal.
Great i will have a meeting about the plugin with dev... thank you!
also cuestioning about xml/soap for webservices... it is neccesary for this service monitoring too?
@Harshal P.
Hi @robert p.
If you define the Message Broker in DC RUM with the HTTP analyzer, it will automatically pick up the Web Services. No additional configuration is required.
