Can we do a Ping test for load balancer IP from SaaS Model Dynatrace?
srinivas_krish2
Newcomer
Hi, Is there a way, we can do a ping test from Dynatrace SaaS model to a loadbalancer IP? or is there a possiblity to install an Oneaget to monitor the azure load balancer component?
Thanks and Regards
Srini
Philipp_Kastner
Dynatrace Pro
Dynatrace Pro
Hi Srinivas,
currently there are no ping tests. However we are working on HTTP checks which are able to monitor availability of HTTP based application / services from various (also private) locations.
As long as the load balancer offers an HTTP endpoint that would be a possibility.
Kind regards, Philipp
