Connectivity problem kube-proxy and Oneagent
kamlesh_a_verma
Newcomer
I have configured Oneagent on K8S cluster using the following link.
https://github.com/Dynatrace/dynatrace-oneagent-operator/tree/release-0.4
After configuration, I am seeing an error "kube-proxy kube-proxy (kube-proxy-85qvd):Connectivity problem" under Problem section.
Activation of deep monitoring was unsuccessful
Monitoring of statically linked Go programs that do not load libc is not supported
I understand that kube-proxy unable to communicate on a few ports but I am not seeing any errors in Kube-proxy or dynatrace logs.
3 REPLIES 3
gerard_habchi
Newcomer
We're running into the same issue with EKS
mayana_s_khan
Inactive
443 and 8443 ports are opened between k8s containers and CAG/EAG servers?
Download the support archive and check for erros in logs.
Host-->Process and Container(select the process which Activation of deep monitoring was unsuccessful) -->click on the 3 dots and download support achieve.
check the logs for errors.
Mayana Khan
israel_chavez
Newcomer
hello, anyone found the answer for this?
