Dedicated module for IBM MQ monitoring
Babar_Qayyum
Dear All,
From the following list which module is used for the IBM MQ monitoring? Can we disable all modules on the ActiveGate except the module related to the IBM MQ monitoring?
We want to bound the IBM MQ monitoring only to the dedicated ActiveGates.
Babar
Mike_L
Dynatrace Guru
Dynatrace Guru
The IBM MQ monitoring is done both by the full stack monitoring OneAgents, Extensions 1.0 on the OA when using the following extension: https://www.dynatrace.com/hub/detail/ibm-mq-oneagent. Out of the AG modules it's the Extensions 1.0 one when using the extension from the hub: https://www.dynatrace.com/hub/detail/ibm-mq/
Mike
Mike
Hello @Mike_L
Thank you for your prompt response.
Babar
