Dynatrace Managed - Problem noticifation types
bernhard_madlma
Participant
i have 3 Questions regarding the Problem notification module:
- Is it possible to send the Content of the "Custom Integration" in XML instead of JSON?
- Is it possible to call an executable file?
- Are there any future Plans for an Integration with HP Event Management Software?
Regards
Bernhard
jeff_keizer
Newcomer
wondering if anyone had any updates on this post, looking to integrate Dynatrace Managed Problems into OMi Event cosole
raffaele_talari
Inactive
Hi Bernhard,
1 - Currently that's not possible. But I believe @Wolfgang B. would like to hear what's the use case for requiring XML instead of JSON.
2 - I'm afraid it isn't.
3 - Not that I'm aware of.
Ciao,
Raff
