Dynatrace Oneagent installation automation script of mass deployment
sangeetha_mitta
Organizer
Hi
Could you please help us with the below requirement?
We have got requirement to deploy oneagent to monitor 1200 hosts?
Could you please share if there is any sample automation script for mass oneagent deployment(Chef/Puppet)?
Thanks&Regards
Sangeetha
4 REPLIES 4
kulwinder_singh
Inactive
Hi Sangeetha,
What sort of environment you have? Windows/linux
plus i can write scripts for automation but our environment is a SaaS one and that too syntheics module only. So will have to check out for way to automate this it should not be very difficult though. if you can give me the answer to above question i can basically create a script for it and you can test it on few servers and let me know how it goes.
regards,
Kulwinder Singh
Thank you for the response. Our environment Dynatrace SaaS and is Linux. We have large environment with 1200 hosts to be monitored. Please help us with the script for mass deployment of oneagent. Also, please share Synthetic module script as well, as going forward we are going to get that requirement as well.
Also please let us know, the steps on how to run the script
nj_njoku
Inactive
Hi Sangeettha,
These are presently available in Github. See below
1. Chef - https://github.com/Dynatrace/Dynatrace-OneAgent-Chef
2. Puppet - https://github.com/Dynatrace/Dynatrace-OneAgent-Puppet
3. Ansible - https://github.com/Dynatrace/Dynatrace-OneAgent-Ansible
Hope This Helps
NJ
