Help with regex for place holder of web request naming rule
Hi guys,
Need some help with regex for place holder of web request naming which need to fetch the word in the end of the url after "-"
From regex tester its look $|-(\w{1,})$ should do the trick
But its not seem to works within Dynatrace.
If removing trailer $ ($|-(\w{1,}) we can see its fetch the word after the first "-"
Any suggestions how to get the word after last "-" in url?
Thanks in advance
Yos
ChadTurner
Leader
I was using Regex 101, what if you used: -(\w{1,})$
-Chad
Hi @Chad T.
Thanks for your checking, unfortunately its not working with in dynatrace 😞
For some reason the $ at the end of the regex with in dynatrace is not behave like in regex101 or dynatrace regex tester
Yos
