How many resources does the on-premises installation need to receive, analyze and run smoothly
r_resina
Newcomer
Hello, I'd like to know how many resources does the on-premises installation need to receive, analyze and run smoothly when you ask for the dashboards
sebastian_kryst
DynaMight Leader
DynaMight Leader
Hello, you should look at this table:
https://www.dynatrace.com/support/help/deploy-dyna...
Everything depends of amount of OneAgents and user actions that you want to track.
Regards, Sebastian
