How to monitor Docker containers running in VSPHERE INTEGRATED CONTAINERS
satit_dpm
Participant
Dear all,
Monitor Docker environment is easy with just installing OneAgent in Docker hosts or deploy OneAgent as a Docker Container in Docker hosts.
However, I have encountered a customer running Docker Container in VMWare Virtual Container Host (VCH).
This VCH is a logical host with an associated endpoint VM based on Photon OS.
You can SSH to this endpoint VM with vic-machine CLI debug mode, however, you cannot install anything in it as it will not persist once this VM restart (it will restore from VM image)
Anyone has experience deploying OneAgent in similar architecture?
Satit
ChadTurner
@Satit A. were you able to monitor docker containers in Vsphere? did you run into any issues? Did you reach out to support on this? Were there any issues/lessons learned that you ran into?
-Chad
