Integration issue between NAM and Dynatrace Managed
Babar_Qayyum
Dear All,
Unable to integrate the NAM 18.0.5 with Dynatrace Managed. Any support will be really appreciated.
Babar
matthew_gardner
Dynatrace Helper
Dynatrace Helper
It looks like there is an issue with the token you are using. Did you get the integration token from the Dynatrace UI? (Settings -> Integration -> Dynatrace Modules -> Generate Token for NAM)
Also, if you have not found this already, here is some documentation on how to integrate NAM with Dynatrace:
https://www.dynatrace.com/support/help/setup-and-configuration/integrations/dynatrace-modules/nam/in...
Hopefully this helps!
Matt
Hello @Matthew G.
Yes. I generated the token for NAM and using the same for the integration token.
In the Tenant URL I am providing the following to integrate one of the cluster node:
https://000.000.000.114/e/748f0a80-a63e-4556-816a-3d2c062de9a7
Babar
