Monitor Filesystem of Process (ActiveMQ)
bernhard_madlma
Participant
on our openshift enviroment, we have the problem that a Filesystem connected to a pod is running full (eg. /opt/amq). Is it possible to check for this metric in Dynatrace (ie. 90% of volumne full) on the process level?
Bernhard
ChadTurner
Guru
@Bernhard M., were you able to get this set up? I have not seen anyone do this but would be very interested if you were able to get this to work.
-Chad
marcos_garcia
Newcomer
Go to settings, Anomaly Detection, Infrastructure. Add a new custom disk-detection rule. The rule should include the only disk names containing /opt/amq/data and only for the hostgroup with Amq. On the same rule, alert if free disk space is lower than 20%, for example.
