how to create BT for click button in Dynatrace managed
ramakrishnan_p-
Organizer
we have a scenario where i have to click the button. how can i perform the same in Dynatrace managed? example with screenshot will help.
RamP
skrystosik
In dynatrace you have to do couple of things.
First, by default dynatrace is not using naming of user actions click on button XXX like appmon did. But clicking of this button is resulting some request I suppose and this action should be marked by you as key user action. Then you can add it to dashboard and count instances on custom chart.
https://www.dynatrace.com/support/help/shortlink/u...
Regards, Sebastian
akshay_misra
Inactive
Like Sebastian mentioned above, you mark it as Key user action and then use it in dashboards & charts.
In addition you can also mark it as a conversion goal.
