on running oneagentsdk.rb using trufflruby there is an error as "undefined function typedef ,callbacks" might be issue in reading .so file please suggest
aditiaggarwal11
Newcomer
sonja_chevre
Dynatrace Pro
Dynatrace Pro
Hi Aditi,
from the title of your question, I can understand you are trying to use the OneAgent SDK. what are you trying to do? what is the use case you are trying to solve with OneAgent SDK? a little bit more context would help 😉
Sonja
