Dynatrace tips
Post F5 deployment configurations for management zones and tagging rules.
Peter_Youssef
Leader
As simple as possible, the below parameters are configured after the successful installation of the F5 extension on the target monitoring tenant:
  1. type(f5:disk)
  2. type(f5:instance)
  3. (f5:interface)
  4. type(f5:profile)
  5. type(f5:rule)
  6. type(f5:pool)
  7. type(f5:pool:member)
  8. type(f5:pool:virtualserver)
for more customizations you can add for example:
  1. type("f5:pool"),entityName.contains(/xyz)
  2. in "", or without ""both scenarios are applicable
0 REPLIES 0
