02 Oct 2024 12:57 PM
Hello Dynatrace community members,
Finally we had a solution to discover all Pluggable databases automatically without the need to follow manual addition or insertion method to The PDBs in parallel with Container databases, only you will configure the CDBs and the PDBs will be discovered automatically.
The tested solution is related to this issue which has been raised before.
Solution
After applying the below commands while adding the required user permission as per Dynatrace Hub requirements, you should find all PDBs are discovered in parallel with the CDBs.
Peter.
