ActiveGate Plugin SDK Installation Issue
Babar_Qayyum
DynaMight Leader
DynaMight Leader
Dear All,
While installing the pip3 install plugin_sdk-1.175.270.20190920.173335-py3-none-any.whl, the request is going to hit the proxy and getting the timeout.
Why do we need the proxy to install the plugin?
According to documentation, the ActiveGate is bundled with Python 3.6.6 and we recommend to use Plugin SDK with the same Python version but there was an older version which we upgraded to the 3.6.8 manually.
https://www.dynatrace.com/support/help/extend-dynatrace/plugins/activegate-plugins/introduction/writ...
Babar
sebastian_kryst
DynaMight Leader
DynaMight Leader
did you try opening of support ticket?
Hello @sebastian k.
First, I wanted to discuss with the community, but now I will have to open a parallel support ticket.
Babar
