Extensions
Adding a custom SVG icon for Custom Plugins
r_weber
DynaMight Leader
DynaMight Leader
I want to add a custom SVG icon to my technology plugin. Currently this is not documented at the Plugin Reference page (the documentation seems a bit outdated/incomplete).
I know that the plugin metadata also supports the "favicon" attribute that would allow to specify a URL to a pixel-graphic (like png). This would then be used in the Technology view in the Dynatrace UI.
If one specifies a favicon like so:
Dynatrace would include that in it's Technologies page with an url:
In the case of jpeg/png this would work fine. But as this graphic is scaled on various pages it looks ugly.
For built-in Technologies Dynatrace uses SVG graphics.
How can one also use scalable SVG graphics in own plugins? I haven't found any documentation on that.
3 REPLIES 3
Julius_Loman
DynaMight Legend
DynaMight Legend
I ran into the same situation and I could not get it working either. I ended up with a large-enough png that scales up correctly.
Mike_L
Dynatrace Guru
Dynatrace Guru
You're currently limited in the image formats that you can use as a favicon. Please create an RFE as it makes perfect sense to improve it and include it in the new extensions framework currently under development.
The favicon concept is documented on the extension json explained page: https://www.dynatrace.com/support/help/extend-dynatrace/extensions/reference/json-reference/extensio...
Mike
Mike
r_weber
DynaMight Leader
DynaMight Leader
Ha, the documentation is ahead of the plugin reference! Thanks!
For the RFE, will create it!
