Ceph Storage Monitoring
echwallah
Advisor
Does Dynatrace have visibility into Ceph Storage including its block, object and file storage.
If not is there a RoadMap to provide visibility into this Storage System?
Dynatrace Certified Associate
echwallah
Advisor
I have seen the Extension on Hub for Ceph Storage.
For remote Monitoring the second step asks for an Prometheus endpoint and authentication.
Could someone clarify whether this comes natively or it is something that needs to be setup like an instance separate from the server having the ceph storage
