Dynatrace administrator who has the below permissions on the monitoring tenant, can configure extensions from Dynatrace Hub.
For WebLogic, the below oneagent service should be configured and services restarted.
- Access the monitoring tenant > Manage > Dynatrace Hub > WebLogic > add to environment.
- The oneagent should be deployed on the intended servers, and monitoring data is flowing into Dynatrace.
Tip:
- Ensure extension execution controller is enabled on the target hosts, otherwise it won't work.
