Dear All,
What is the difference between cordova-plugin-mfp and IBM Mobile First for Apache Cordova?
Is the following plugin support both platforms?
https://www.npmjs.com/package/dynatrace-cordova-plugin
Babar
https://www.npmjs.com/package/cordova-plugin-mfp According to this page it seems to be the same.
Hello @Sebastian K.
I had a small chatting with one of the support persons regarding the same subject, and he said it is not straight forward for the IBM Mobile First, and we will have to do some additional settings to make it work with the Dynatrace.
I will update the information here if they confirm the above statement.
Babar
Hi @Babar_Qayyum, I know it's been a while, but do you recollect how have you gone through this issue? How did has it end eventually?
